Wow that sparked alot of discussion
I am burning a St. Croix multi fuel with the slide out bottom burn pot. I have been burning straight corn since 2009. I have put approx. 27 tons thru it. It burns very clean. The ash stuck to the surfaces inside ranges from snow white to tan in color. Then the heavier weight ash is black that falls to the bottom. With the correct stove corn burns as clean or cleaner than pellets. The one thing with corn is there is no creosote in corn.
As far as corn quality, We buy straight from the farmer. I have a couple buddies that farm. Some years it comes out of the bin, if we have a dry fall I have got it straight from the field. Other years it was left from the harvest the prior year and spent the summer in the bin. I have never had problems with fuel and I think the St. Croix is not real finicky with fuel.
I suck it out with leaf blower mid winter then in the spring. I vac stove and ash traps out every couple of weeks. Some weeks the stove runs for 2-3 weeks with out shutting off by dropping the clinker block on the fly.
I have replaced bearing in distribution blower a couple of times that is about it. Original Combustion blower and fan blade. There has been no added cost for parts do to corn corrosion.
This stove is a manual ignition. 1 cup of pellets and a little gel. Throw a match in and go to work. It lights every time no problem. My wife can light it and drop the clinker block on the fly. I have not seen a stove that was easier to run and burnt as clean as the St Croix with corn. But what I see the most of is Harman PC45 which is the worst corn burner in my opinion.
