Wow, thanks CT Yankee for the This Old House recommendation and Kenny for the link. That is exactly my oven!
I can sort of get my head and an arm in there to do some repairs if I lay down on a platform or table of some sort. My wife actually helped me with some repointing on an exterior brick wall to the house and she was quite competent (really good manual dexterity). She is small and I would love to get her to crawl IN the oven to repair it... but I know she will freak out even at the suggestion hahaha.
Thank you Bholler for info regarding NOT parging the interior of the brick oven. Maybe just some repointing. There are some joints that could obviously use it, but surprisingly it is pretty solid overall.
There are no combustibles at all (just brick, mortar, plaster) except for the piece of green trim. The only place I was considering ceramic insulation is deep in the hole above the door, where that repair starts to get little but close to that trim. Yes, I would use bricks in the repair (I did not mean to imply only cement)... and fortunately I have some OLD bricks from various eras of the early house construction laying around (plus the loose ones I pulled out of there).
I assumed I would use refractory cement, but simple N type mortar would be very forgiving to the changes in temperature, and more similar to what is in there. I have not researched this yet. Do you guys happen to have recommendation on this?
The floor of the oven is in surprisingly good condition. I wonder if it was redone at some point. It is uniformly shaped and fairly large rounded bricks. It is nice and flat.
This house is essentially two houses connected together. The newer front portion of the house is made of brick and this is where I have put a small Jotul 3TDIC-2, and I am also in the middle of installing the Woodstock Fireview. From all the research and investigation I have done, that newer part of the house is from 1850 or slightly after (and was listed by realtor as 1855 arbitrarily).
The part of the house we are talking about now for this post is the old wood house connected to the barn, and it is significantly older. This side has not only hand hewn beams, but things like hand made nails in its construction, etc. The date is unknown but certainly some number of years earlier than 1850. This portion of the house sort of needs to be heated separately, because there is a thick exterior wall between this wood portion and the newer brick portion.
This chimney is huge and is an interior chimney. It's condition is pretty good, all things considered, but of course it is an unlined masonry chimney. This chimney has also been ruined by the same clown (certified chimney expert) as the spray foam and undersized liner situation from my previous post. There is a brick channel (like a separate flue) that comes from the basement where some wood burning was done in early days of the house. Later, the basement furnace vented through there. Then they then put a 7" flex liner in it, and when it wouldn't fit easily, they smashed out the entire channel all the way to the top of this historic chimney (previous owner, remember). That liner is a ridiculous and shocking situation that has to be the topic of a completely different thread (likely in the furnace section) and should have some appalling photos.
But anyway, I originally wanted to remove that poor liner and line the entire old chimney with cement. In fact, a mason quoted me on a job where he would wear some kind of suit, climb through the chimney, press his body on the sides, and thereby line it with refractory cement.... like Santa Claus I suppose (I am not making this up). He was a cool guy, but has disappeared.
- I know that nobody wants to do this kind of masonry anymore... but I wonder if it is possible (and desirable) to preserve the large cross sectional area of that chimney and line it with cement so that the rumford fireplace and brick oven can function in their original way.
- The other option is obviously a flex liner to the brick oven. Would that function better or worse in that manner (compared to it pouring into the huge chimney)?
With the second option I have to give up the fireplace, which I struggled with, but I can connect the beautiful old antique stove that shows some flames through a screen. It would get only very occasional use and would be just for ambiance and a bit of extra heat during some dinners (this is the dining room). This old side of the house is just heated up at the times needed (and where needed). I can post about the antique woodstoves on that side separately in the antique section of the forums.
As far as the other question from CT Yankee:
- Modern cap? There is no cap on the flex liner, haha. It is just sitting there open. There is also no top plate with hole holding the liner up. I don't know what holds it in place (rebar?), but the masonry chimney is open to the air and has tons of draft (dust flies right up it spontaneously when inspecting it). There is a solid piece of sheet metal on top of the chimney lifted up by 2 and a half widths of brick to basically keep the rain out. I am attaching photos.
When I first bought the house, the previous clown (chimney guy) of the previous owner wanted to
do a bunch of work including a (too small) liner for the fireplace and an exhausto fan. Between that and the other existing liner from the basement furnace in that chimney, I asked (in writing) where the brick oven smoke would vent and they wrote this in reply:
"The brick oven smoke would flow between the liners, it would just be fly ash smoke- not creosote, I am sure the oven is designed to work effeciantly (sic)."
What does this mean, and is this correct?
Thank you
![Cool old Brick Oven - get it working again Cool old Brick Oven - get it working again](https://www.hearth.com/talk/data/attachments/289/289941-a6c689da4828c5eb45c4d50de9332683.jpg)
