I have a Thermo Control boiler that has a tendancy to overfire and the route I took to control this issue was a thermocouple in the stack, PID temperature controller and damper actuator on the air intake. My wood has not been the best this first season and I did not want to take the barometric damper route due to what I have read about those possibly feeding chimney fires with air. True/false who knows - I did not want to chance it when I'm off at work. My "system" runs in series with the factory setup (which is near non existent in my opinion).
Do any of the gurus on this site have any experience with this? I would like any comments on the pros/cons of doing this. Do the Eko's, Econoburn's etc do this already?
The thing thas has me baffled the most is creosote buildup. At a constant stack temperature of 450 degrees how does this happen? Reduced stack velocity? I can run at 450 degrees for 7 hours straight but dependent upon wood condition I can have creosote buildup. If I run at 550 degrees I have minimal creosote buildup but my burn times or shorter. The 450 degree setting maintains the boiler water temperature longer for the afternoon.
I have never had problems with this boiler meeting the heat demands of the house. I have had problems with creosote buildup. I should be much better next year with better wood (seasoned) but again any inputs on this would be appreciated.
