Hi All,
I have had a few threads of issues i have been working through with my stove and chimney set up. I pretty much have everything buttoned up with the exception of a smell of smoke above the side door handle which seems like its coming from the top of the firebox seal, pic attached with arrow for reference. Some quick details, I had the chimney extended to now a total of 20 feet, chimney company added a stretch of class a pipe to the top of my chimney. I also previously had 2 90 degree bends coming off the stove which includes the T in the masonry chimney. I now replaced one 90 with 2 45's. So between the chimney extension and the 2 45's the stove drafts much better, no smoke in the room when im starting it up and seems more stable. Also, fresh splits measuring 15-18%. The issue is that when I have the stove loaded and its cruising along gassing off all the way until it transitions to the coal stage there is a constant smell of smoke above the side door handle near the firebox seem. I know most say if you have a good draft regardless if there is a leak in the stove smoke wouldn't escape rather air would leak into the stove causing your stove to not burn right. Is it possible you could still have smoke leak out under a good draft? With the stoves flute in the center if you have a bad seal off to the side not directly where its drafting could some smoke escape since draft i would think be less on the outskirts of the stove? I think im at the point im just going to call the place that i bought the stove from and have them come out and see if there are any physical issues with the stove (this is my last resort and hoping i dont have to call them, they dont have the best customer service history for warranty work)
![Continued Manchester smoke issues Continued Manchester smoke issues](https://www.hearth.com/talk/data/attachments/305/305575-7fa1b57d6920d80dedb58c6e44c7008f.jpg)
