We have installed 20 Windhagers since November of 2012 and right now, have 5 more scheduled to go in before this winter. (4 of the commercial sized units and 1 residential so far)......... .....We'll see if the weather cooperates with our timetable.......
![Oops! :oops: :oops:](/talk/styles/default/xenforo/smileys/ohh.gif)
To date, our customers have not experienced a single part failure of any kind. Nothing. It's pretty boring really, they just sit there and run.
Two of them were installed on a large dairy farm exactly one year ago today. When I went there to check them the first of this month both of them had over 30 tons of pellets through them and both hour meters are in excess of 6,000 hours of run time.
Nothing has been done to these boilers other than routine cleaning every 600-700 hours of run time. This severe duty use is the equivalent of probably 4-6 years of heating a normal house type load and there have been no failures to operate for any reason.
We really like the engineering we see in the Windhagers. A few examples would be........
If you ever need to remove the pellet motor and auger assembly for some reason, it takes about 20 minutes. Pretty much everything is laid out with ease of service in mind. Very easy to take care of.
No O2 sensor to wear out. Their combustion control is based on temperatures at various locations in the boiler, rate the water temperature is changing and actual water temperature along with a few other parameters they are tight lipped about.
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
The feed rate and draft fan speed are variable independently of each other.
The condensation protection is built into the boiler which in most circumstances eliminates the need of a mixing valve or other boiler protection device.
A thorough cleaning takes about 20 minutes once you have done it a time or two.
So far they have been bulletproof and I would give them 5 stars.
I can't speak to the Kedel as we have no experience with them
