Hi All:
I'm hoping someone has some experience with either/both of these stoves?
A little background info. I have two stoves in my house, a new VC Montpellier insert that I installed last year. I had an old airtight insert for a long time, the Montpellier gives me such a great view of the fire that I have considered changing the other stove ( older airtight something like a fisher). That stove is a corner installation in a family room. We spend most of our evenings in there and usually just put a small fire on to take the chill off -- let the Montpellier do most of the heating. What I really would like to do is have a stove in there that gives me a great show, the airtight has a cast door and there is nothing to look at.
The room is small and I think I would like a soapstone stove to moderate the heat and allow me to burn a longer fire without overheating the room -- the room has a double door on it so the heat can escape to the rest of the house as long as the stove is not burning really hot.
Now, the stove choice?? I have a dealer close by that has a Hearthstone tribute on sale -- the stove looks very small to me and I haven't really seen a lot of discussion on that one. I like the looks of it, it has a front load that may work well for me since this is a corner install.
The Woodstock Keystone also really appeals to me, I am concerned about side loading with the corner installation. I did tape it out on the hearth and looks like there should be a reasonable amount of room to put wood in from the side. I have a few questions about this stove. Is the glass hard to clean and does it get very dirty? (I have well seasoned wood) Is the EW burning with the side load something that you guys like? Does the stove look larger than the Tribute? Do you get the same show from the firebox with a cat stove as you do from other EPA stoves?
I am concerned about placing the order since I live in Canada and have to get the stove shipped to me. Moving a 500 pound stove into place may be a bit tricky. I guess I have to decided before the sale is over.
Thoughts???
Thanks in advance
Glenn
Thoughts???
Thanks in advance
Glenn
