I removed a majestic wood burning fireplace from my house, it was connected to a stainless 8" dual walled pipe. The inner pipe is 8" and the outer 10". The length is between 20' and 25'.
I'm planning on getting a Morso 1410B to put in it's place, I have all the clearances around the stove itself sqaured away, but I'm trying to figure out what I need for the flue.
I know that you're most likely not supposed to connect directly to this pipe, since it was for a fireplace application and not a wood stove. Is there any other option besides running a full chimney liner? There is an immediate 30 degree bend as it goes up, and that bend spans about 5 ft in length before going straight up.
Can I run a length of 6" pipe from the stove up until this bend?
Thanks alot.
Bonus Question: Out of curiosity, if the existing stainless pipe is rated for 1600 degrees or whatever, and it has good draft, and the pipe temperatures at the top of the stove should always be around 300-600 degrees...what is the big risk here?
Thanks alot.
