I guess it doesn't make much sense to me..
I am not disagreeing with you, but if you actually do the math it doesn't end up being too much. If you run 2 or 3 gallons of splitter fuel to make your winters heat vs. 4 or 6 gallons of diesel would the extra 20 bucks in fuel warrant having another gas engine around? I prefer the engine on splitter, but there really isn't much wrong with using a tractor either if ya already have the power plant. Just different strokes.
Actually if you dug around YT enough you might find that there are alot of those kinda splitters mfg and in use in Europe. No machine of any type can be saftly operated if the person using it is lacking in grey matter betwixt the ears. I do like this splitter though. I'm sure PETA dont but then, well, They can all freeze to death far as I'm concerned.
Athens Enterprises, 3637 Chestnut Level Rd. , Liberty, Ky. 42539 - 606-787-0266What is the splitting mechanism on that? That horse doesn't mind that at all... it's really no different than lunging them... You've got to exercise them in the winter.. otherwise they get cranky... I know the walking horse/ standardbred mare I used to have did...
Machines like that have been around for hundreds of years in one form or another. That horse is probably happier than iffn it was just standing in a cold stall doing nothing. Kinda like owning a good hunting dog and locking it in a kennel in the back yard 24/7.
.. but plumbing codes no longer allow it...
Hmmm...they allow water storage for watering a garden (rain water). I think I could get creative enough to call it something legal.![]()
Screw type splitters are still available and common in europe. Considering their strong safety laws, you have to wonder if the doom-sayers over here are wrong.
Check this out, a cordwood saw and a screw type splitter in one!! A double whammy of "dangerous" firewood making. Enough to cause the OSHA types to have a minor stroke
BTW anyone thinking of making one of these, or modifying a posthole digger in the manner of the Atom Splitter should be aware that they come with RH or LH threads - an RH thread will not work on a PTO of post hole digger without a very complicated reverser. The PTO versions like the Bark Buster used the LH thread. Stickler used to make a LH model apparently, but only makes RH now. I learned this the hard way, having bought an old cone only to realize when I got it home that it's the wrong direction. So anyone got a LH thread cone they want to part with, let me know!
I have a friend who has a couple of these splitters, one of which he runs direct drive off an old industrial engine of 50 HP or so. Works just great and he is still alive. with things that look dangerous, it is often hard to tell just how dangerous they really are. Lot of people badmouth these rigs whenever the subject comes up, but damnfew seem to have any firsthand experience. It is worth noting that Sticker continues to make the kind that bolt on a truck axle, which would seem to me to be by far the most dangerous. It's unlikely they could have stayed in biz if the things were a tenth as dangerous as they look. The banning of the Bark Buster is hard to explain - there were a dozen of so other, almost identical rigs that did not get banned. The major thing the BB was faulted for was not having any kind of cutoff switch; the current version of the Sticker has one, and one is easily added to any of the older machines. My idea is to put a "panic bar" across the top and sides that will kill the engine if it is pushed or pulled in any direction.
My motivation for looking in this direction is I want some thing small and simple, without bringing another nasty little E-10 swilling motor into my life. A 3 pt cone splitter is one of those machines like scraper blade or cordwood saw you can leave in the bushes for 5 years, then pull out and use again. Try that with a Home Depot hydraulic splitter! Sure a tractor is probably less fuel efficient than a GX or clone but for the amount of splitting I do who cares. And a 3 pt. mount makes a very handy package in the woods compared to dragging a trailer splitter. Plus I like the option of changing work height and being able to put the cone right down above the ground and spilt logs as they lie.
The sticklers will work on a posthole digger but they wont work direct drive from a tractor PTO.
This is an early model stickler with a fixed bolt pattern.
I bought it at a garage sale many years ago.
It wouldn't fit any of the vehicles I had at the time.
I pulled a rear end from a junked car that it would fit on and adapted the drive shaft to fit my tractor PTO.
The tractor that I had at that time didn't have a 3pt hitch so I welded a tongue to the axle and pulled it to where I wanted to split wood.
I jacked up the right side removed the wheel and mounted the splitter.
I locked the brake on the other wheel.
I used it that way for many years.
Never had an injury.
Later I replaced the tractor with one with 3pt and hydraulics and bought a 3pt splitter.
I saw a video of one on a posthole digger on youtube so I adapted the stickler to mount on my digger.
I still use it occasionally to split larger logs.
If my situation was such that I only had a couple cords a year to process, the wood wasn't exceptionally large or diffficult to split, then I know of an even more economical way to get it done.
That's sort of the joke of it all. The splitting I need done would be easily done with a maul, but I had my shoulders done and can't use one. Hence my search for a simple alternative. It just isn't worth it for me to buy $1400 trailer splitter, or even $500 PTO pump, for what I need to do, but it's incredibly frustrating not to be able to split a bit of wood when we need to. And those hand powered HF ram splitters? Too horrible to contemplate.
......Are the two (?) flat stock spreaders at the top the way the splitter came or did you add them? The current Stickler has a steeper angled cone there, to give the splits a finally kick to separate them, and my friend with a similar splitter has been thinking of adding something like you have on yours.
I don't know.... I can see the dangers.
This thing needs a big red kill switch right beside the cone....
