Hi,
I need help understanding the clearances for this diagram. It is for the Jotul Firestove 3 Woodstove.
It is currently installed upon an Imperial stove board that is not big enough. That stove board is resting upon a wood floor. The wall behind the stove is also not properly protected. We just moved into the house and someone from the insurance company came and took a look inside and said the wood stove has to go. I had the fire department come take a look and they said that it should be okay if the hearth size and wall protection is properly installed.
I am trying to get away with the smallest, least intrusive, affordable option for it to be up to code. It's a small room and a small house.
According to the diagram it is configured as T4. The stoves dimensions are 13deep, 22wide, 20tall (not including the 8inch legs). What do the side clearances need to be on the non combustible sides? I am most likely going to purchase another Imperial stove board for the floor but want to be sure on the dimensions required before doing so.
Help!
![Conflicting information for clearances Conflicting information for clearances](https://www.hearth.com/talk/data/attachments/239/239781-ba25024b071c36aa5f26bbf8ffc6abee.jpg)
Help!
