Hi all
I'm new here.
I have a Pacific Energy insert like this one
http://fireplacestop.com/product/pacific-energy-super-wood-insert
I use it to supplement heating my house. I mainly heat with my natural gas furnace, but I light a fire several times a week in the winter. The insert is an EPA stove. What I want to do is set up an Adurino micro computer to control the damper so that the insert will automatically adjust to keep the fire in secondary burn.
Here's how I imagine it will work. The damper would be adjusted by a 12 volt linear actuator. I would place a thermistor somewhere on the insert that would read the temperature of the firebox. If the fire gets to hot, the computer closes the damper a few millimeters at a time until it gets to the right temperature, and opens the damper if the fire gets to cool. You get the idea. Instead of monitoring the fire and manually adjusting it, this would do it automatically. It might need two thermistors, one for the top end of the temperature range and one for the bottom end? The end of the actuator could be coupled to the damper with a magnet so it could be overridden if necessary, such as when you want to open the damper to add wood.
Some things I don't know. How hot should the fire box be to give a clean burn? What range of temperature would work for a clean burn? How hot is too hot? I have read about some people who are measuring the temperature in their stove, how are you doing that and where are you doing that?
I realize that this may seem like a lot of effort for little gain, but I like to tinker, and I like efficiency. I have never built anything with an Adurino and I would like to learn about them .This seems like a good application.
I am open to ideas about the design and need information about the temperature needed.
Thanks
I'm new here.
Thanks
