Now, I've been thinking about this for the last couple of days and I might have had a breakthrough is proving to myself that an electric heater is cheaper to run, at least when that's the only thing that's being run (either summer, or maybe winter too if the stove is running and heating the house for the most part).
The DOE test procedure requires, in part, heating 63.4 gallons of water to 135F, and the test takes place over 24 hours.
I'm pretty sure, again, based on memory and some readings I took off my water softener, that my entire inside useage is 40 gallons per day. I figured 30 gallons of that was hot water. I was able to use that number to use the annual kwh on the Energy Guide yellow tag, which, typically seems to be 4773 for a 40 gallon tank. Electric cost was assumed $.15/kWh.
The oil consumption I got from looking at some past bills, but because of the periods and a different owner, maybe not that confident..could be lower. AVC8130's might be better, or it could be something in the middle - I put all three in the attached spreadsheet.
I couldn't believe it when those three annual oil use scenarios came out to $1037, $526, and $701, respectively, and the electric scenario came out to $334! It blew my mind. This is with 15 cent electric. Resistance, not heat pump. And, a $240 water heater.
Please tell me if I'm wrong!
I'll get working on firming up my oil and water consumption numbers, but I think they're in the ballpark.
(Also, Moderators, not sure if this is the right forum to post this, but there have been other similar threads here of late. )
![Comparison of DHW Oil Indirect vs Electric Tank Comparison of DHW Oil Indirect vs Electric Tank](https://www.hearth.com/talk/data/attachments/73/73247-50ab338624153da177279aa6b279844f.jpg)
