Does this help tell what the temperature will be like under the stove? It’s a Drolet Columbia II. This is from their manual.Stain should be ok and the sealer, maybe, especially if the stove has an ember protection only hearth requirement. A water-based sealer would likely be safer. Look at the product data to see what the maximum temperature rating is and its combustibility.
That is an ember protection only hearth. A sheet of metal would suffice. What product would you like to use on your concrete hearth?Does this help tell what the temperature will be like under the stove? It’s a Drolet Columbia II. This is from their manual.
You could. But why not just a piece of sheet metal painted? Or unpainted. You don't really need high heat either. The stove only needs ember protection so the temps won't be high
No problem. If you paint it with Stove Bright paint there should be no temperature worries. Their color 6201 Charcoal is a medium gray.I would like this exact hearth pad., nothing changed, .. colored with a medium grey ,however I have to do it to be safe to put my stove on. Color it grey and call it a day. I guess I don‘t see why this is so difficult to answer. I’m sorry!
It's hard to answer because we don't know what material that is how soft and pourous it is etc.I would like this exact hearth pad., nothing changed, .. colored with a medium grey ,however I have to do it to be safe to put my stove on. Color it grey and call it a day. I guess I don‘t see why this is so difficult to answer. I’m sorry!
I don’t need a steel anythingI would like this exact hearth pad., nothing changed, .. colored with a medium grey ,however I have to do it to be safe to put my stove on. Color it grey and call it a day. I guess I don‘t see why this is so difficult to answer. I’m sorry!
It's hard to answer because we don't know what material that is how soft and pourous it is etc.My stove company didn’t know why the tiles came off but assured me it’s safe as is. The bottom of the pad would show if there was water damage I would think. We will be scraping the rest of the residue off. We can tell you the surface isn’t soft! Our hands almost fell off…Yes, it is unknown territory additionally due to thinset residue and the unknown reason the tiles became unbonded. Painting it will be an experiment but the Stove Brite will at least be heat tolerant and comes in a variety of colors. FYI, many years ago I spray painted a cement board wall shield with high temp paint. It was used for a decade with no issues.
How is concrete polished?Think about how to install the stove without scratching the paint badly. Personally dyed concrete that I could polish some would be where I would go.
Rattle cans of grill paint would be easier. Personally I don’t see the need for stove paint. It won’t get hot enough to cure.
Some good 180 grit sand paper to scuff and a really light first coat.
If filling the pad I would not move after I added concrete. Wouldn’t want to risk cracking out.
Hey,How is concrete polished?
