This kind of goes with the cold air thread but I thought it deserved a seperate thread. I have found that putting cold wood into the boiler has a big effect on the time to get the temp up on the boiler. It makes me understand the effect having water surrounding the fire box has as far as cooling down the flame. I have a BIG boiler so the effect is larger but I was having a hard time trying to understand why when I loaded it up and had good gasification going my water temp would go down. I totally isolated the boiler and just circlated the water in the boiler and it still went down. it took quite a while and the temp would go down sometimes several degrees and just slowly went up. then when it got up in the 160 range it would heat fast. What is happening is the cold load of wood is pulling heat from the water in the upper chamber and it takes alot of heat to heat that wood up. From a cold start this can take quite a long time to get the water up to that magic temp of 160 plus to make gasification work the best and was one of the problems I was having in the fall when I was starting from a cold start. Now that I understand it I make sure I don't fill it all the way up on a cold start even if gasification is going. I can then go back and finish filling it when the water is up there.
Another thought I have is on a cold start you could start your fire and get coals started, then take a propane rosebud or weed burner on a wand and aim it from under at the nozzels and heat the nozzels up which should get things going faster. Has any one done this and your thoughts![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
leaddog
leaddog
