hey, thats sounds good. now when you say place styrophom between the floor joists, should it be placed directaly up against the subfloor? Meaning, could I tack it up there somehow?
Adirondackwoodburner said:hey, thats sounds good. now when you say place styrophom between the floor joists, should it be placed directaly up against the subfloor? Meaning, could I tack it up there somehow?
BeGreen said:caulked all the way around very carefully, then 1.5" styrofoam (milder climate) glued to the inside of the foundation and finally 6" fiberglass between the joists in the rim joist pocket at the ends.
Highbeam said:BeGreen said:caulked all the way around very carefully, then 1.5" styrofoam (milder climate) glued to the inside of the foundation and finally 6" fiberglass between the joists in the rim joist pocket at the ends.
Begreen: I see no mention of vapor barrier in your setup. Did you simply glue the XPS directly to the stem wall and leave the poly vapor barrier on the ground or did you do something else? Thanks so much.
tutu_sue said:Here's is a link to information on weatherproofing your crawlspace: http://www.eere.energy.gov/buildings/info/documents/pdf/29238.pdf
First, try sealing the sill plate and all plumbing, electrical etc. penetrations into your house from the crawl space. If that doesn't do it for you, then you may want to insulate the ends of the joists (aka rim joist and band joist) above the foundation. Finally, you can consider insulating the interior crawlspace walls. Based on the type of foundation and joists you have, you can insulate using foam board insulation (Option 2) on the inside of the rock foundation. Taking measures to control moisture before installing insulation is vital to long term success.
Good luck and keep us posted.
