Cold Air Intake Pipe
Parallax
922
Bellingham, WA
For my cold air inake, I've got an adapter attached to the stove and another attached to the wall. It's about an 8 inch run but not in a straight line. What sort of pipe should I run between the two? Flexible would be easiest but is it alright to use? Is there a particular brand? Can I buy it online? Thanks.
Aluminum dryer duct is ok. This is usually available from the local hardware or big box store.
Reactions: Parallax
I used aluminum dryer pipe and painted it black
Reactions: Parallax
That's plastic. I would order something more heat resistant. This would do:
Thanks so much. Just ordered.
Also ordered these screws to try to fill some holes from the old stove installation. The holes are a bit larger than the standard screws typically used with stove pipe. Went with #10s. Let me know if there's something you'd recommend instead.
They're machine screws which need a threaded hole. Typically, sheet metal screws are used instead. Something like this:
The trouble is it's a double walled sleeve. When I try to use 1/2 inch screws, they push into the inner wall and won't go all the way in unless I drill into that wall too. I thought it would be better to just go through the outer wall, which requires 3/8 inch screws. Am I wrong?
Sure
The crimp shrinks the pipe. Think about the crimp on singlewall. One end is crimped so it fits inside the other piece.
I think I might have found a way to do it. Crimping with a needle nose pliers. Hope it works.
I bought a crimping pliers at some point.
Unfortunately you're a bit far away to borrow it ..
Not this one but something like this:
Yeah, no idea who made mine. I got them 20 years ago. They sit in a drawer unused for years until they’re needed, lol
Reactions: stoveliker
Generally a crimping tool is not used on flexible pipe. Often a start collar that has one end crimped is installed instead.
Alright, managed to get the aluminum tube running into the house adequately crimped with a pair of piers and was able to wrestle the CAI flange attached to the stove into submission. So it's all hooked up. Way more work than expected but it's done.
Now I've noticed another problem. It's been raining today. A few years ago, I had a leak down the stove pipe. Brought a guy out who calked the seam in the Selkirk stove pipe. Thought that had fixed it but I see now that there's still a bit of water coming down.
I assume that needs to be fixed before completing the installation. Otherwise, the stove will rust. Is that true? Are stove pipes typically completely immune to rain water coming down on the inside?
The seam of the stove pipe? Or the class A chimney outside?
Stove pipe is only used in the room where the stove is.
I assume the chimney pipe outside.
The horizontal seams or the vertical one? I had to caulk the vertical seam as that was the one that leaked.
