DickRussell
Joful said: ↑
I remember woodgeek setting me straight on this before, but I still honestly don't understand putting enormous effort into a house to make it as tight as a plastic baggie, and then purposefully ventilating with outside air. Seems there might be some ideal passive air exchange level, which might be less costly than the current methods of sealing tight and then venting.
Yes, this has been explained before. Especially for a house in a heating climate, you simply can't "build a normal house and let it breathe naturally" in any way that provides the right amount of fresh air for any particular set of conditions, let alone all conditions. That'd be a complete roll of the dice. The house will leak most in bitter cold, windy weather (US NE since yesterday noon or so), and essentially not at all when temps are 60s-70s with no wind. Just as bad, you can't control "natural leakage" at all. The amount of "natural" leakage under worst conditions may still be excessive (making the air inside bone-dry, causing cold spots - especially if heating with stove - and wasting energy) or it may be so tight that the air inside gets too humid and stuffy. Perhaps as bad is that the leakage is through the myriad cracks and holes in the shell, resulting in the insulation becoming (over time) a collecting place for tree pollen, dust, dead insect bodies, and perhaps rodent feces. Ask your wife if she really wants her "fresh air" filtered through that.
So the only practical way to build a better house, from a building science and health point of view, is what's now said: "build tight - ventilate right." Make the shell as tight as you can get it, using well-understood techniques, and provide for mechanical ventilation. In areas with a serious winter, it pays to do that through a heat exchanger (HRV, ERV), to recover much of the heat going out with the discharged air and warm up the fresh incoming air.
yes, it is called build a normal house and let it breathe naturally.
![[Hearth.com] Code Question ~ HRV [Hearth.com] Code Question ~ HRV](https://www.hearth.com/talk/data/attachments/153/153837-ee402488d20c9ec1034f9ffdeef81ca1.jpg?hash=ewSLDwHBJ8)
![[Hearth.com] Code Question ~ HRV [Hearth.com] Code Question ~ HRV](https://www.hearth.com/talk/data/attachments/153/153881-31cf12721418eea8d0c86ace8e46255d.jpg?hash=jAJ5sYPcTL)
