You guys have it easy, lol.
My house was built in three stages, and each has it's own wiring, each section done by a crappy electrician. The only part of it that was done correctly was the mudroom I built this year. I have found everything from unboxed pigtails, old crumbling cloth wire, too many outlets on a circuit, bad switches, bad outlets, ungrounded outlets, double grounds, exposed wires, 10 wires taped together with electrical tape, an unsecured sub panel (just hanging in mid air), main panel right on the floor, loose wires not in conduit, wires buried under lots of insulation, etc.
I'm looking at a whole re-wire job. Just for kicks I had an electrical contractor come look and give me a bid for $13,000 bucks to fix everything. Let me think about that one for a minute, do it myself for about $2-3K or pay you guys... hummm. I just work on the worst parts first, and slowly fix things up as time and money allow. What else is a guy to do?
-Kevin
-Kevin
! sealed it up with... Ubetcha urethane caulk. stuck the tip of the caulk gun into the hoselike stream and into the hole, about 6 or 8 pumps, sealed. Not a probelem ever since. Fixed about 4 other leaks in this basement that supposedly didn't ever leak. Found sh-t burried in the high brush which is not dead & low, in several spots around the property. Of which I must dipose of now. Found 30amp bereakers installed in 15 amp circuits. Just too many to list, and too many to be a coincidence. Previous owner sais the end of basement floor drain is out at bottom of hill on side of house. Been down there 5 times, found nothing. I think he burried it under some cinder blocks that are out there, or another object. Inspector inspected all outlets & everything. No I am finding them miswired, pulled out from behind the push ins. I can't say he did all this. The drain is a pretty suyspicious indicator though. That I won't let as chance happening. I must find the other end. Glue some 2" pvs (about50-70' worth) together. Push it up the outside end of the basement drain (3 " or 4"pvc) and try and push the rock or whatever it is back to the drain and try and grab it. But I have to find the outside end first. Going to wait til snow, pour some dyed hot water down that drain and look for steam & colored snow. I only fear he did not run it out the hillside and it stops underground in a drain pit. In that case, I'm f'ed. I'll knock a whole in the floor , put a 5 gallon bucket and put a sump pump in it if thats what I have to do. He didn't run "J" channel around some of the windows & doors, It rains and the water runs behind the siding and down to the basement plate and into the basement. This is a cedar shake look fiberglass/vinyl siding. Not like regular vinyl with weep holes. Alot of crap is what it all is. Told me the breezeway ceiling & walls were insulated. They aren't. Luckily I can do that as I have the framing exposed & the attic able to be gotten into now. Other stuff is fine, so I am lucky. Its not everything. The main house is insualted to the hilt. 6" walss full insualtaion with 1" foan behind the siding. Not a breeze to be felt. So It could be worse.
