Limited test results have been done as the cob corn supply has been short. But 20% (est.) ear or cob corn has burned well in my EKO40. Using a bed of coals from wood as the starter base (don't start easy otherwise) the corn ignited and gasified well. A blue flame was quick to appear after a short time with the corn on the coal bed and little ash residue in the secondary after a complete burn. The corn will dry on the stem, as long as the ears turn downward, to a desirable MC percentage without needing any special drying facilities. No specific storage facilities will be needed as long as you don't mind hand picking or hand pruning (shucking would not be needed) otherwise arrangements would be needed for larger quantities. Full load burn time is about 6 hours max at zero degrees F. and very little wind and the boiler comes up to heat fast because the fire is hot early (blue flame at 120*f boiler temp). A few chunks of oak or other high btu/dense wood will extend the burn time. Loading is pretty easy with a bucket or frustrating by hand. Transitioning between wood and corn and back is as simple as whatever you choose to throw in next. Some would think it expensive but not if you have the place and experience to grow it. But it could be time consuming. For those who run out of good dry wood for whatever reason cob corn could be a very reasonable choice if you can come up with a low cost supply or need an emergency alternative fuel. I'm gonna try to grow a half acre next summer. If things go/grow half way well it should be about equivalent to 2 cords of 20% 21-24 million btu wood.
!! LOL
