Co-Gen Pellet Boiler
Cool concept ....may be a while before it makes sense for the average household but you got to love the direction pellets are going.....so long as the cost of pellets remains reasonable
This boiler has been running through the paces for quite some time now good to see they are comfortable enough to release it on the public. Cool concept
Is this DC or AC? Seems like icing on the cake and it would tie in nicely with net metering. Could it even generate its own power requirement, separating you from the grid? Hmmmm.
AC 50 Hz according to pic below. 120 Volt / 60 Hz versions must be available too.
[Hearth.com] Co-Gen Pellet Boiler
Man, even if they took the idea and scaled it WAY back.... to the point where it could simply power itself/its blowers by running much like a car does. Needs a battery/the wall to start, but once up, it's on its own free will to run without wall power for, well, ever.
i'd be a buyer for a unit like that. Takes the generator out of the picture.
If it could feed hot water, it could also feed my radiators instead of the oil pig.
forced hot air from the unit, and indirectly get hot showers and a little bit from the radiators, and it gets me power on top of it?????
i'd pay 10 grand for it.
For 35k theres a lot better heating systems to be had. You can have a full blown geo system which would be cheaper to operate.
No thanks.
You'd have to feed it constantly, all year round.
I think that would be a pretty big pellet bill.
Naw, you'd revert to an electric/heat pump water heater for the summer. Only use this in the cold months. not as a power plant.
this basically balances the low daylight hours of winter for solar panels that can run the 1kw/day in the summer.
That is correct. Mind you, if you want to build a new home
in Austria, your home needs to generate a portion of the energy you use... That's where this, solar and wind power options come in.
Hello
I like the idea of the vacuum fuel feed option better than the big Auger fuel feed.
See
(broken link removed to http://www.maineenergysystems.com/OkoFEN_AutoPellet_Boilers.htm)
