I am finding a buildup of liquid creosote in the flue pipe of my wood furnace. It is coating every part including the Field R-C Damper, which I find difficulty in cleaning. I cannot seem to stop it from forming. Recently, I cleaned the flue pipe of the menacing stuff after a hot burn to bake it. The wood from the supplier was sold as seasoned and I have had it stacked for two months prior to burning. I found a load of year old seasoned wood, but the cost was close to bio-logs and I could only afford 1.5 cord.
My wood furnace heats the house really good, firebox temps running around 450 to 575 degrees Fahrenheit, and inside flue temps when I'm able to measure at around 390-degrees, and outside flue temps at around 195 to 250 degrees; temps measured with laser gauge.
Any ideas out there as how to adjust the furnace for a hotter burn or less creosote would be helpful?
