I have a "unique" installation.
In my living room there was a "raised" fireplace, maybe about 1.5 feet off the floor. The fireplace opening was about 3 feet wide by two feet tall, with a 8"x12" clay tile lined flue.
A previous owner (probably during the early 80s) had built a brick hearth in front of this and put a wood stove in front of the raised fireplace. The wood stove flue (8") came straight out the back of the wood stove and went 10-12" into the fireplace. This passed through a metal "plug" that closed up the fireplace opening.
I removed the wood stove (which I had never used), dropped a 4" flexible steel liner down the chimney and trough the damper opening (I removed the actual damper to make room for the liner). This is a run of less than 15 feet. Then in the fire place I adapted this to 3" and connected to a 90 degree elbow to point out of the fireplace. Then a 12" piece of pipe goes through the 8" opening in the plug (sealed around it with fire-proof ceramic insulation) where there is another 90 degree bend to point the flue pipe down, then a 6" section of pipe down to a clean out tee attached to the pellet stove.
I could brush the liner from my roof with a 4" diameter brush, but then the problem is cleaning from the first 90 bend inside the fire place to the 90 above the clean out tee. I can unhook some of the 3" dura-vent and move the pellet stove out of the way and vacuum out the 90 bend at the bottom of the flex liner but this would be a huge pain in the ass! There is no way I would do this more than once a season.
Any other suggestions?
