Bell and Gosset sent the following instructions for cleaning their flat plate heat exchanger. Thought I'd pass them on.
"Some suggested methods of cleaning either side of the heat exchanger are listed below: Back flush with a high pressure stream of hot water to remove loose deposits. Circulating hot wash oil or light distillate will usually effectively remove sludge or similar soft deposits. A 5% solution of Phosphoric Acid or Oxalic Acid may be effective in removing more stubborn deposits. For optimum results, the solution should be in a back flush type flow pattern. Rinse heat exchanger with clean fresh water after use."
Not sure what they mean by a hot wash oil, or a light distillate. I'm going with the oxalic acid as I have some out in the garage.
Mike
Mike
