Wow, this has truly been an amazing thread! All sorts of super interesting stuff on electronic, light, magnetic, and thermal theory and also one of my personal favorites (and minor from my Bachelor's Degree) Biological Psychology
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
If Milt were to workout internship opportunities I might actually apply and just cut/split/stack/load firewood for him while taking thorough notes on anything he has to share, seriously. Anyway, I have four hopefully simple questions specific to the ceramic glass in my Regency Alterra.
1st. Is the ceramic glass that is in my stove "Coated" as some other types of regular glass apparently are or is it only ceramic glass without any additional application/s of material/s?
I'm not sure about the answer to this question.
2nd. Based on the answer above, if it is coated, is that on the inside or the outside face? If it is on the inside face is it possible/probable to wear that off over time?
I'm also unsure about the answer to this question . . . but I suspect that the wear factor is not a real issue.
3rd. Is it okay in general to use the method of dipping a damp rag into the ashes to clean ceramic glass or is that only the method for cleaning regular glass?
I think you should be fine doing the damp rag and ash tip . . . although I will tell you that one thing I picked up last year was that if you are burning properly at the right temps with well seasoned wood you shouldn't end up with a lot of baked on gunk -- now I most often only need to use a damp rag without any ash to clean the "glass." Right now I'm using Rutland "Fireplace Glass Cleaner" Liquid (which takes off majority of stuff which wasn't really resistant) I then use the Rutland "White Off" Cream to get the rest. I'm completely cleaning the glass before each fire for the time being as I'm still in seasoning mode for the stove and learning mode for myself. Even though these products work perfectly well as others here offered in other threads why pay for something the stove gives you!?!
4th. I know from many folks here it is okay to use the IR thermometers on the glass whether it is regular glass or ceramic glass BUT is it also okay if one's IR thermometer has the laser to assist with aiming? My thermometer is the Fluke 561 and I've always wondered whether the laser that's on that meter would manage to hurt the ceramic glass in any way whatsoever? I know that sounds sort of hyper to ask about but since my stove is so new I'd rather ask the stupid stuff now before I have a chance to screw something up later!
I doubt the laser would do anything to the glass or coating . . . but I probably wouldn't aim the laser towards any aircraft flying overhead or around any law enforcement officers.
Thanks folks, this forum continues to impress the helloutof me in many ways
