D
DexterDay
Guest
Gman12 said:Ok, I'll try. It's when I first turn the stove on that I hear the fan or blower. Doesn't do anything with the thermostat when I turn it up or down. Then the stove just shuts off after a while I had been pressing the reset again. Where exactly do I wrap those wires in the back of stove I cut off of the thermostat wire? I did have them hooked into the middle ones. Can I turn on the stove and keep control box cover off to look at lights and patterns?
Plug the stove in and leave it plugged in. Everytime you re-plug the stove in. The combustion blower runs a cycle. The stove IS NOT trying to start. This is something the stove does. Its in the programming. So plug it in and let the blower shut off. Once it has shut off (after 18-20 min)
Now. Take your thermostat off. Remove the wires from the terminal blocks. Cut a 3-5 inch piece off of one of those wires. Take this little piece of wire and strip both ends. Now connect the ends to the terminal blocks (no thermostsat / throw it in your closet for now/ lol)..
Once the wires are attached. If nothing is wrong with the stove itself. The red call light will come on. Do all of this and report back.
! I cut the wire and connected a 4-5" piece on back (without thermostat) after letting stove shut down. As soon as I put that wire on....stove started back up and red light is now on. What do I do now? Thanks again for getting me this far.
