In some recent posts, I've read about how cold starts can be a bit smoky without preheating the flue. Especially when offsets are used and the stove has 90* bends in the black pipe.
At some point down the road, I will be doing an exterior Class A. I have also observed exterior chimneys of all types, do better on the southern exposure walls. Mine is a north westerly wall where the stove will live. I will find the benefit of no exterior offsets. Just two 45s in the black pipe to transition to a through the wall Class A. Chimney will have 20-25' of height. Once heat is established draft will be plenty strong. My thoughts to combat cold starts is to build an insulated chase, with a hinged bottom for cleanouts at the T.
Thoughts? If there are no foreseen issues, I hope someone can benefit from this idea.
