Clarification on BTU needs calc. for my home
here is what I learned..
A 23.5k btu kerosene heater will keep our home pretty comfortable. Running non-stop.
A 50k btu woodstove will do the same, but only if pushed hard. 4/5+ loads a day
A 80k btu woodstove will do the job and give us good long burn times.. 2/3 loads a day.
How big is your house? How cold does it get in the winter? How well insulated?
As for the computer fans... ok, but I'd need to rig up a power supply. But I do have a few desk fans I could put on the floor that are relatively quiet. Would I need to really run the (loud?) blower on the BKP then?
My point was what we found to be true for our house and location, again just an observation. If I remeber right the bTu calc I played with many years ago says 31k is needed for heating..
2100sqft two story, over full unfinished/uninsulated basement. Built in 96, standard 2x4 construction, R 13 walls with Tyvec wrap under vinyl siding, 16" blown in the attic, 20 double pane windows, two sliding glass doors and 3 "regular" doors (2 with 1/2 or more glass).
Average "winter lows" from weather.com say:
Oct 45F
Nov 35F
Dec 27F
Jan 23F
Feb 27F
Mar 34F
I don't know how they figure such data, (it was 15F last night) but assuming you compare it data for YOUR location, from the same source, (weather.com) it should allow for a comparison point you may be able to use.
Disclaimer: every install is different. Your results WILL vary.
