I live in a concrete, earth covered home. It currently has a 40 year old kozy heat wood stove installed in the center of the home. It has a 5' vertical run of single wall black pipe coming directly off of the stove. Beyond this, it passes through about 2.5' of concrete. The piping through here is 8" stainless that has about 3/4" heat resistant insulation around it. After the short run of stainless, it transitions to about another 6' of 9x9 clay lined masonry. Upon cleaning this year, my brush pulled up a jagged piece of metal. Disassembly of the interior piping shows that the stainless pipe is rotted at one of the joints, about 2' up the chase. My plan was to replace the stainless but now considering getting a new stove. The new stoves all seem to use a 6" flue so there should be room to pull in some type of liner. I am looking for some insight on the best system to use. I believe that it would need to be insulated although the chimney never comes anywhere near any combustibles. This also makes me wonder if i could just install standard double wall pipe through the old chimney chase. The major obstacle I am seeing is that I need to transition from double wall black pipe to the liner at the concrete ceiling. I would like something that is aesthetically pleasing and somewhat serviceable. Of the systems I've looked at, they all seem to use masonry thimbles that are meant for horizontal install and not vertical. I will add some photos if that would help. Thanks for any tips!
