Chimney Problem (Pic)
Jay106n
806
Litchfield County, CT
I am having chimney problems and I just can't figure out what the problem is, any suggestions? ;)
[Hearth.com] Chimney Problem (Pic)
Newest EPA testing.
Reactions: Jay106n
a little c-4 will straighten that right out
Reactions: Jay106n
Looks good to me. I suspect you're burning poor quality wood...
Reactions: Jay106n
What the wife told you to tie a knot in it
:p
An exterior chimney won't draw as well...
.. A block off plate may solve that issue
The responses are killing me. The sarcasm level is through the roof! Its gotta be that darned pine...
Reactions: LocustPocust
Can't believe that bholler hasn't admitted installing that chimney yet.
Does it have s single or a double liner? Is it insulated if it is a single? Some Roxul might help a bit...
I'm surprised nobody has pointed out the double chimney caps with only one fire place.
And I wonder if trumpets increase the airflow...
I think the problem is wet wood - knot the chimney.
needs doors, open fireplaces are terribly inefficient!!!
Reactions: Jay106n
