If that were true, the stove would not burn at all when the door is closed and the damper is shut. But it obviously does.
Give that a try on a warm day and get back to us.
That is because the heat differential causes draft with out that heat differential there is no draft.
You do realize that to tight a house in the summer can cause lots of issues.
do what i do in the summer and open the windows then that tiny amount of air moving through the stove wont matter in the least.
On a hot day, the stack effect of the house draws warm, humid air down the chimney
Ok what was the temperature differential? Air is not going to rush out of your house at the top unless the temp or pressure in your house is higher that the temp or pressure outside the house. It is that simple.A couple of years ago I cut a 1 foot diameter hole in the ceiling of a 1-story house, then went into the attic and felt the air rushing thru the hole, blowing my hair. The house with the stove is 2-story, so I would expect the natural draft to be even worse.
Yes but how will that tiny amount of air effect the energy efficiency of your house?Yes, I'm pretty familiar with building science, but I don't think I'm going to cause any problems by plugging the chimney.
I understand that but people tolerated those temps for a long time i have absolutely no problem with you using air conditioning but don't tell me about being as energy efficient as possible if you are going to. Because no you dont need air conditioning you can survive fine with out it.In Georgia there's a limit to what is tolerable without air conditioning.
No the stack effect draws for high pressure to low pressure. That is very basic physicsNow that makes no sense to me - I thought stack effect always draws from bottom to top. But either direction, I don't want air moving in the chimney.
Too bad 9" is the smallest they make. I'll bet if I put the 9" in a 6" chimney it won't end up being air tight. I think just a disc with a gasket on the edge would be best.
Yep, I misstated that stack effect would occur on a hot day. Maybe if the attic got real hot, I don't know. Now, at night the house may be warmer than outside... At any rate, I've seen moisture in my stove so I plug the chimney.Air is not going to rush out of your house at the top unless the temp or pressure in your house is higher that the temp or pressure outside the house.
yeah it can happen for sure but it is rare in most cases i find it is much better to let the little bit of air move through the systemYep, I misstated that stack effect would occur on a hot day. Maybe if the attic got real hot, I don't know. Now, at night the house may be warmer than outside... At any rate, I've seen moisture in my stove so I plug the chimney.
Or a free sample from caplugs.com. that's what I use on my pellet stove venting.
Wait, I thought those were just for mosquitoes.The plastic cap on a 34 ounce coffee can fits perfectly on a six inch chimney pipe. I will sell you one for $34.99 plus shipping.
Those things catch to much gunk!!Why not just put a bird cage up top, at the cap?
What "gunk" is coming out of your chimney? You burning wet wood? My cages seem to stay clean enough.Those things catch to much gunk!!
You must be one of the pests that I try to keep outWhat "gunk" is coming out of your chimney? You burning wet wood? My cages seem to stay clean enough
