Hi everyone,
I hope this is in the correct forum. I have a wood burning fireplace I've installed in a house I just built. I installed one of these: https://www.efireplacestore.com/sup-wrt2036wsi.html
Now when I say installed, it's only mounted in the wall opening so far. I now have to figure out the chimney pipe setup. I live in Central America (i know i know, a fireplace in central hot america
) so we won't do very hot or frequent fires. 10-15 small fires every winter. My wife's dream has always been a fireplace in the bedroom which is why I installed it.
Yes I built the house to US and/or International Code, but there is no inspection or homeowners insurance here. The roof is metal, the walls are cement and block. I don't plan on doing this 100% the proper way I would back home in the States. I just need it to have enough draft to burn a fire when needed. It's only for ambiance and not heating the house or room.
The fireplace has an 8" open on the top of it. I need to rise about 8' feet to penetrate the roof and need to angle over about 7'. Then I'll come out the roof 4' or 5'.
My question is, can I just use 8" flexible stainless pipe, wrap it with insulation to the roof line? The chimney I'll figure out after. If I can use flex, can I reduce to 6"? I have to ship the flex from the States to here which is not cheap. So I'm trying to see if I can use flex if I can reduce to 6".
I'm looking at this on amazon: amazon link
and then I'll wrap it with insulation 1/4" or 1/2" if needed.
Summary:
Metal roof, cement house, no combustibles within 12"
Can a chimney flex pipe be used?
Can I reduce from 8" to 6"?
Is insulation needed and if so 1/4" or 1/2"?
I know I'm probably missing a bunch of info so if you have questions I'm all answers.
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Summary:
