Hey there! No verdict as of yet. My chimney/masonry guy went over it with a fine tooth comb, so to speak, sealing every conceivable leak on the brand new chimney, but it still leaked same as before. So naturally he says it has to be the flashing, which he is kicking himself for not replacing. But since we're now in the dead of winter, he had to tarp the new chimney (leaving holes for the dryer vent & fireplaces) and is waiting for a non-icey weather window to pull the flashing off and see what's going on.Soooo, what was the verdict??
#$%&!!Currently in the same boat. Roof guy says no way it’s the flashing, chimney looks to be in decent shape. Scheduling mason to come out and look at the chimney. Plan to have him tuck point, seal the crown and the brick, and go from there. Probably doesn’t hurt to have that done anyway.Hey there! No verdict as of yet. My chimney/masonry guy went over it with a fine tooth comb, so to speak, sealing every conceivable leak on the brand new chimney, but it still leaked same as before. So naturally he says it has to be the flashing, which he is kicking himself for not replacing. But since we're now in the dead of winter, he had to tarp the new chimney (leaving holes for the dryer vent & fireplaces) and is waiting for a non-icey weather window to pull the flashing off and see what's going on.
The roofing contractor who hired a guy to flash the chimney insists that it cannot possibly be the flashing, of course. But if it's not the brand new chimney leaking, then what else could it be BUT the flashing? I'm no expert, but it seems like it has to be one or the other, right? Anyway, hopefully will know more soon...
Thanks, Steve G.
Make your chimney guy come back and replace the flashing properly as he should have with the rebuild. It is not properly done and should have been fixed thenHey there! No verdict as of yet. My chimney/masonry guy went over it with a fine tooth comb, so to speak, sealing every conceivable leak on the brand new chimney, but it still leaked same as before. So naturally he says it has to be the flashing, which he is kicking himself for not replacing. But since we're now in the dead of winter, he had to tarp the new chimney (leaving holes for the dryer vent & fireplaces) and is waiting for a non-icey weather window to pull the flashing off and see what's going on.
Thanks, Steve G.
Any problems with the siloxon staining ur roof shingles?When my leaked one guy said it was the flashing, he fixed it, still leaked, another guy said you need a cap, still leaked, third guy said to coat the stone and cap in siloxon and that stopped the leak, now I coat every 2-3 years and no problems.
No, it's a clear liquid, I forgot to do it a couple of years and it leaked again, I coated last year and the leaking stopped.Any problems with the siloxon staining ur roof shingles?
It leaves streaks on shingles and a haze on metal.No, it's a clear liquid, I forgot to do it a couple of years and it leaked again, I coated last year and the leaking stopped.
this mason came highly recommended and is recognized as the best in the area. He finished a few days ago and last night it rained an inch, and guess what? The chimney STILL leaks!
Since I stopped leaving it up to pros, my living room is dry as a bone. The basic difference is I care
I wouldn't recommend sealing the masonry unless your masonry units are abnormally pourous. It should not be neededGot a quote today from a very reputable company. Redoing the crown, grinding out old mortar to the roofline, filling with new, and cleaning and spraying entire chimney with soloxane. $2000. Seems fair for the amount of labor
If they soak up allot of water lol. There are tests but generally someone who works in masonry for a while can tell.How would you tell if they were abormally pourous?
.And that does happen we use it when appropriate. But it is usually just something some chimney guys add on to increase profits.Ha ha.
Well in my case I kept getting water dripping out from the the brick above the fireplace. It was Bone dry from the ceiling to about a foot above the fireplace. A roofer told me it was pourous brick after he ruled out the flashing. The siloxane cured it.
