Hello all, Last season we replaced our old kodiak stove with a newer epa hearthstone phoenix. Almost immediately I noticed that the existing chimney was going to be a problem. The flue will not stay warm enough to get a complete burn along with trouble starting the fires. The existing chimney is 8x8 terra cotta exterior block . I'd like to reline with a single wall stainless but after measuring the clay flue : a little over 6 3/4" and the inside thimble 6" inside diameter. Wondering if this is feasable. How could you make a connection with a T in this situation? The stove pipe entering the thimble is a snug fit a few inches of pipe into the thimble. Some pictures are attached. Any help would be appreciated. Stove uses 6". Current install 6" single wall
