Chimney help
Massery94
3
Sand lake, NY
Looking for help on installing a new wood stove. Ran single wall and found out that’s a no no. Can’t figure out what kind of class a pipe will fit this.
[Hearth.com] Chimney help
Yikes. That is really unsafe. I am glad you asked for help.
The blocked-off corner is a waste of space. I'd tear it all down and set the stove properly in the corner. That will make the room larger and it will permit a safe installation of the connector pipe. Also, the stove may work better.
Reactions: Dieselhead
Do you know what manufacturer that chimney pipe is?
Where does it say you can’t run that far horizontally?
Every chimney manufacturer gives a maximum allowable horizontal run. We need to know what type of chimney you have. But regardless you can only get 15 and 30 degree elbows even if allowed I don't see how you would make it work. And maintenance is not going to be fun.
As a professional I would not work on this setup as is and wouldn't be willing to even try to make the connection with class a as it sits. There is just to much potential for problems
There is a difference between (black) stove pipe and chimney pipe.
The former can run horizontal, but cant go thru a wall. Once you go thru a wall it has to be chimney pipe (class A chimney). And that has limits on horizontal distances.
