DeadTreeBurner
Well, again, the ebay listing itself does not say anything about insulation, let alone requiring it for zero clearance.What does the included listing info say? What does the installation instructions say about it?
The install instructions do not mention insulation either. Instructions do state: The "Forever Vent Chimney Lining System from Chim Cap Corp. is intended for use as a relining system for clay lined masonry chimneys only. Tested and approved to UL1777 zero clearance standards for masonry chimney serving gas, oil or wood burning appliances."
Instructions also recommend that a qualified Professional installs the kit, that it's sized per equipment manufacturer's instruction and local building codes and to contact your local building department or fire officials about restrictions and installation inspection in your area.
Chimney the liner is to be installed in must be checked for safety and repaired if necessary before installation.
So nothing at all in the listing or instructions about requiring insulation wrap, just that it's tested and approved to zero clearance standards in masonry chimneys. To your average consumer, that means it can be placed in any clay lined chimney that's in good repair. If they know a purchaser will be informed after purchasing by their inspector/installer, IF they use one, that insulation is required, well that's pretty deceptive. Because it appears from their advertisement/listing and install instructions, by themselves, that you don't need one. And we both know a large number of people will be installing liners themselves.
