This would be a great question for the firemen here. When a chimney fire is just starting, do you recommend letting it escalate and making a phone call for help or do you recommend putting it out if possible? Similar question about a grease fire on a cook stove. Do I put it out or let it burn? If I put it out I may possibly splash grease. If I make a phone call my house is likely to be destroyed before the arrival of the firemen. Also, if you recommend stopping the fire, how do you recommend a homeowner do it?
First off . . . most folks prefer the term firefighter today.
Partly because we have sister firefighters working right alongside the brothers . . . but also because "fireman" is a bit of an outdated term.
Loaded question to be sure . . . but I can only say what I personally recommend in my classes.
The pat answer most fire experts would say is to always leave the home and call 911 from outside. This is truly the safest course of action in terms of life safety . . . but it's not always realistic to expect folks to just stand back and wait for help to arrive . . . whether it's in a town or city will full-time, career firefighters, a community with a mix of paid/volunteer firefighters, paid-call firefighters or all volunteers.
My own, personal advice for a chimney fire is to call 911 at the first indication there is a chimney fire. Get us on the way. If the fire burns itself out or the home owner is able to extinguish the fire there's nothing that says you can't call us back to advise us that the fire is out. Most FDs will still respond to be sure the fire has not extended. Plus . . . it's better to get us on the way sooner rather than later in case you cannot get the fire extinguished.
If you feel comfortable AND can do so safely my own technique for extinguishing a chimney fire personally depends on the type of install. Quite frankly, I don't see a lot of chimney fires in newer hook-ups with newer stoves (i.e. Class A, liners, etc.) Most of the chimney fires I have personally been to involve traditional concrete block or brick (sometimes lined with a clay liner, sometimes not). Since many of these have basement or first floor clean outs I will open this up and see if any hot embers have fallen to the base. I will then use a tablespoon or two or three of water and put it on the hot ember . . . allowing the water to turn to steam (steam expands) and let it be carried up to the fire with the natural draft. I will try this a few times to see if this has any effect. Plan B: Get to the roof top and toss down a baggie full of Class ABC fire extinguisher powder or use a Class ABC fire extinguisher in an effort to extinguish the fire. Sadly, if the chimney fire is due to lack of maintenance (often) usually we have to resort to using a chain and weight to break through the creosote plug . . . and at this point you really should let the FD do this since the chain will often come up cherry red and it's nothing you want to be holding on to without some really thick gloves. It may go without saying that you should close down your stove . . . some folks have recommended tossing a damp (not soaked) newspaper on the fire . . . I cannot say if this is good or bad as I have never done this.
Grease Fire: Use a lid or something like a cookie sheet to cover the pan on fire. Turn off the stove. Let it cool for 10-15 minutes. Do not move the pan while it is on fire to get it outside (the most common thing people do), throw water on it, suffocate it by putting a dish cloth on it, toss it outside and set your neighbor's lawn on fire, etc. An extinguisher can be used . . . if properly rated . . . but only as a last resort since doing so will ruin your meal and make one helluva mess. Again, though . . . if in doubt, we recommend folks get out. Homes can be rebuilt . . . folks, not so much.
Incidentally . . . I also try to "preach" that folks be proactive vs. reactive . . . the easiest fire to extinguish is the one you never have . . . which brings me back to my first post (i.e. burn seasoned wood, burn at the proper temp, inspect and clean the chimney) . . . then you'll never have to wonder what to do and if you should call us.
P.S. Most grease fires can be prevented by simply being in the kitchen while cooking with grease since most of these fires start when the cooking is left unattended.
From a recent Facebook post which posts up fires here in Maine . . .
DELAYED. 20:55 Stoneham Fire to 55 Grover Rd in Albany for a chimney fire, with possible extension.
Upon arrival, heat was detected around chimney, which was completely enclosed in sheetrock. A crackling sound could be heard through the ceiling. Went to second floor and noticed smoke coming from around a door frame.
Waterford was then toned for mutual aid.
Weapons of destruction were used to gain access to the chimney in the second floor, finding and extinguishing the flames with foam.
Overhaul was started, checking further extension, both in the attic and first floor.
Waterford was cancelled.
More ceiling sheetrock removed from the first floor, exposing the charred floor that extended 10 feet from the chimney in both directions.
Upon further investigation, it was noticed that the stove pipe fit loosely into the chimney. And that the stovepipe was inserted into cement. No thimble. The homeowner was advised to fix the problem. This was the suspected origin.
Also, the homeowner was advised to fix his smoke detectors, since none were going off during our visit. Had he been asleep during this, the outcome would be very different.
Cleared about 22:00
