Lost time lurker, first time poster.
Had a chimney sweep out last month for an inspection on my wood stove insert. Heartstone Clydesdale. 6" Stainless flexible liner, uninsulated as far as I know.
My chimney cap had come loose over the summer, there was a small oak branch that raked up against it and wanted it re-secured as well as a sweep. He sent his guy to look at it, take pictures, and then proceeded to cancel the sweep and quote me for a new liner, top plate and termination cap. I wasn't home, my wife was, so I was talking with him on the phone, then when I let him know I was only 5 minutes away to talk to him about it he jammed a quote in the door and left as I was pulling down my lane.
I jammed a go-pro with a flashlight on a fiberglass fish tape to check it out. (I know, I know). The only creosote build up was at the top foot or so.
He claims there has been a number of time this liner has caught on fire. I had it swept mid-season last year with no concerns from the sweep and inspection (different sweep, hard to get scheduled).
I have attached some photos to see if you guys think its warranted or if you believe it ever really had a fire. I would do a visual inspection of the flue exit pretty much every time I burned and never saw anything suspect.
![Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced. Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced.](https://www.hearth.com/talk/data/attachments/318/318480-7fe492e00047166a266431a6ff09015a.jpg)
![Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced. Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced.](https://www.hearth.com/talk/data/attachments/318/318476-a762b1d3c91899cabfbf3c550b9db2f6.jpg)
![Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced. Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced.](https://www.hearth.com/talk/data/attachments/318/318477-8103e7158590ca25c0020f20a82a6cdc.jpg)
![Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced. Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced.](https://www.hearth.com/talk/data/attachments/318/318478-ddbf880be549591e743dbdf6f906fad8.jpg)
![Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced. Chimney Cap came loose, Sweep claims I had multiple fires and liner needs replaced.](https://www.hearth.com/talk/data/attachments/318/318479-156e4b4cc48f0ac0c234fbcb8364d49f.jpg)
