(broken image removed)
This is what I'm working with
it is pretty common when you are installing an old insert with a liner that was never really meant to have a liner hooked to it. And no you dont cut the liner at all just crimp the end. An adapter will work well also but he doesnt have one now and crimping it is perfectly acceptable. But with light wall like that you will need to rivit it to the adarter and use backing washers the material of the liner isnt thick enough for screws to work rightI've never seen something like that used.
I'm guessing I need another piece that is going to slide over the appliance adaptor, but inside of the liner correct??
