At my Harman stove dealers today I got and eyeball view of Harman's latest new pellet stove.
Not to be a Debbie Downer here, but I found 2 Very valid reasons I would not purchase this one,
#1...Picture a square box without a top...
This is the Burnpot... it has a metal gate like rectangular piece that slides down In Front of the burnpot..'
Yes. In front of the burnpot causing a 4 sided enclosure...
This "Gate' has holes in it but not round burnpot type but more wavey type I assume for air flow..
My 1st question was," how does the ASH get out?'
he showed me that the " Gate" does not go all the way down but sits approx Half inch above the front of the burnpot so Ash can fall under the gate and out.....WHAT??
OK....I'm not buying one so doesn't really matter why it's there in the 1st place...
Regardless for the reason for this "Gate" which I never found out why it's there,
I soon visualized problems with ash in a boxed in area getting ash dams.
Specially if one was to purchase cheap pellets or any real BBS ashy pellets that form ash cakes or clinkers,
all trying to escape "under" this gate.... it's really less than an inch gap for ash to escape..
#2.
If you are like most who give the burnpot a scrape or two each day, or actually anytime,
there is NO POSSIBLE way to scrape the Hot burnpot Without taking a pair of heat resistant gloves and removing the Gate and hopefully not forget and lay the Super hot metal onto a carpet or bare floor.
The dealer had not read up on this new stove, just got it 2 days ago so he really didn't understand the reason for the "Gate" but it has to be a valid one... but this doesn't change the 2 flaws? that I mentioned that will not change.
I;m sure many will buy it just for the semi--ipad to play with...
just doesn't look right where it is mounted.. dealer thought the same.
I think there is also a light Inside the stove that you can turn off/on..
[that is something I would like just for cleaning and not have to use a flashlight or some external light.]
3rd,
The Absolute is over 4,000.00 for a 43,000 BTU Stove..
This could be a sticky point with people like myself who want more BTU's for our Buck..
My 61K BTU Harman is 3700.00.
It Does have the fancy Digital screen with all the option of setting feed rate, fan speed, temp settings, stock market, weather reports , email and whatever..[Actually the next Generation WIFI stoves will have that I;m sure.
The Harman tried/true technology is the insides of this stove so am sure it will perform as exspected Heatwise but
just cannot go for a boxed-in burnpot for whatever reason. It just screams of agravation and smothered flames from some heavy Ash pellet brands,,:
Note:
Have not read any user manuals but just "might" recommend using pellets with less ash for better performance..?
#2.
3rd,
Note:
