From the manual:
Wall Control calibration: The “Normal Setting†on
the Temp Dial of the Furnace Control (See Fig.44) calibrates
the Wall Control temperature span.If the Temp
Dial is not pointing to the “Normal Settingâ€, the temperature
span could vary by 3 degrees up or down depending
on the Temp Dial knob setting.
I had a guy from Harman today tell me never to loosen the set screw on the wall control knob shaft. He said if there is a difference in temp between what the dial is set at and a digital thermometer, to take the temp setting off "normal" and increase it until the temp on the digital thermometer and the wall control dial agree. WHAT!?
Does the temp dial have an affect on the level of the fire in automatic as well as service? If not in "normal", doesn't it ignore the thermostat setting?
Maybe I'm getting too deep into this thing, but I want to know how this furnace works, not just use it.
