Thanks for the welcome.Welcome to the forum, akhilaggarwal. I believe you are our first member from Bangalore.
If you scroll back thru this thread, you’ll see I used to buy winter weight, and didn’t see any reason to do otherwise, it costs the same as regular weight, at least when buying the same brand. The only rub here is that many cheaper brands aren’t stocked in winter weight, at least not in the southern 48.Old timer next door told me that he use to use cooking oil as bar oil in the winter, way thinner stuff and cheap, wessen I think was the brand he would use.
I was surfing net and found this article for Using An Electric Chainsaw In The RainRecommendations When Using an Electric Chainsaw in Wet Conditions
A wet chainsaw will commonly get wasteful, also the danger of rusted edges. Likewise, there is an opportunity of slippage when holding the machine, which can prompt some heartbreaking mishaps. Water and power have never been known to be exceptionally high together. When water gets inside your electric engine, the likelihood of your device breaking down or neglecting to work through and through will be exceptionally high.
1. Beware of Slippery Cutting Conditions
2. Use Protective Equipment
3. Use the Right Chain Type
4. Be Cautious of Debris Stuck to the Tree
I go with whatever is cheapest, usually it is Wesson.Old timer next door told me that he use to use cooking oil as bar oil in the winter, way thinner stuff and cheap, wessen I think was the brand he would use.
You could add bio diesel in the winter if you get any cold weather.I go with whatever is cheapest, usually it is Wesson.
I have a gallon of regular B&C oil if I ever need it, but so far vegetable/canola oil has been fantastic. Even when it was 0 df outside the canola oil flowed just fine. I don't like cutting in hot weather or when it's single digits or less, so I doubt I'll have any issues long term using organic oils.You could add bio diesel in the winter if you get any cold weather.
