chainsaw stalls
bogrease
7
so utah
my husky 359 runs great for a few minutes and then stalls and acts like its not getting fuel its worse on the mountain 9500 ft i found that if i remove the fuel cap then reinstall it it is ok for a few more minutes is there a tank vent that plugs up?
  • [Hearth.com] chainsaw stalls
sounds like the fuel filter
There's a very tiny vent hole in the gas cap. Forced some compressed air threw it from the inside out ...that should help.
as above plus, are you only experiencing this at the higher elevation or is this your normal. Might have to adjust air fuel mix for elevation. Cap or fuel filter are first 2 to check, additional would be a possible collapsing fuel line ( that is a sneaky one to find) Alcohol in fuel is tough on the lines. The older clear plastic line get hard and brittle and crack the newer rubber lines get soft and gushy and will collapse under suction from the carb pump.
