My b.i.l.'s MS360 Pro that he burned up and I volunteered to try to save him the $375 he was quoted to fix it.
I'm learning that there's truth to the saying "No good deed goes unpunished."
I cleaned up the cylinder and installed new piston and rings. It ran and cut okay but the idle would vary some so I decided to get a carb. rebuild kit. Before installing the kit I had a shop do a pressure test and he said the engine was tight. He didn't pressure test the carb. for some reason, though. So I cleaned up the carb. with air and spray and installed the kit and then I couldn't get it to run. I soaked the carb. overnight and now it runs. I didn't mess with the welch plug, fwiw. I think this saw sat for a bit with ethanol gas, fwiw.
LS and HS out 1 1/4 turns from full in (stops are cut off), nice plug color, 4-strokes for a second at WOT but then jumps to a scream (and I let off). The idle still varies a bit. It'll idle at one speed for 5-10 seconds and then drop to lower rpms for a while. Turning the saw on it's side(s) or upside down has no effect on idle.
I thought all was close to being well. Saw was warm and running as described. Now here's the kicker:
As soon as I touched the chain to a log the saw quit. I freaked and immediately checked the plug. It looked fine. No metal.
It started again fine and runs as described above with no load. I touched it to the log and it quit again. I did notice that the chain had stopped a moment before the engine was completely stopped, fwiw.
Do you have any clue what's up ?
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
