ABMax24
So where would you purchase AVgas outside of an airport?
The airport. Requires an inside connection usually though.
I should note that I do run a lead scavenging agent as well (Decalin RunUp) so that the lead oxide does not build up.
Amazing something fire right up after sitting for 5 years with AVGAS. Ethanol free pump gas wont do that.
AVGAS doesn't have that rank smell that soaks into your skin and evaporates off quickly when spilled. I can't stand the smell of pump gas soaking into my skin with the tiniest of spills. I buy a years worth at a time and store it in 6 gallon race cans.
If I couldn't get ethanol free, I wouldn't bother with high octane. Check your manual, but the stuff doesn't need it. 87 or even 85 (at altitude) will be fine. If I could get one of those ethanol free, I'd use it. They worked great for me in the years before ethanol fuel.Thanks all. I have 4 saws but my primaries are the Echo CS590 and 490, and I use them fairly often. I'll probably do E10 high octane with Echo engine oil and sta-bil mixed in. And will go with low volume so it stays fresh. Just measn I'll need to get gas more often. I typically only stop when my saw runs dry so don't usually leave it with any fuel anyway.
Phase separation is only kind of a real problem, in that it isn't limited to e10. Ethanol's ability to absorb water is the only reason that it can phase separate. E0 will have the first drop of water introduced to the system sitting at the bottom of the tank ...Phase separation is real problem, but easily resolved by not letting old fuel sit in unused equipment for extended periods without stabilizer.
And real tractors run on Diesel.![]()
It isn't the ethanol. When ethanol evaporates, you're left with ... Nothing. Gumming up is the oxidation of the gasThe problem ethanol laced fuel when it sits is evaporation of the ethnol. It leaves a residue behind, that is what gums things up. some of the carb cleaners won't even phase that residue. i have one unit not run very often i do not even attemp to start it with out first pulling the selinoid out for the fuel shut off and cleaning it - it is always jammed up by the ethanol.
I started a saw for a customer that had been sitting for 6+ yearsI should note that I do run a lead scavenging agent as well (Decalin RunUp) so that the lead oxide does not build up.
Ethanol doesn't magically suck up water from the atmosphere. If water gets into your gas, then yes, after the ethanol evaporates the water will no longer be in solution. If water gets into your e0, then it never gets into solution and is laying at the bottom of your tank immediately.when ethanol evaps you are left with water it has absorbed from the atmosphere and whatever other contaminates that have been absorbed by the H2O prior to that. to that extent one then has to look at the reactive agents to /with water and its contaminents in the petroleum product to determin what the xxxx is causing the deposits. so in my simple mind either i blame it on ethanol or less than adequate product from the refineries. fun huh
