G'day All,
I have a Husky 455 Rancher about 4 year old but not used that much (maybe 25 cords of felling & bucking?) in pretty good condition. Yesterday I did about 45 minutes of cutting, saw warned me it was low on fuel as per normal (it kind of drops from high revs and sounds like it is struggling for fuel when the tank is empty - no kidding hey!) and then went to do a second tank after a rest. It took a few more pulls than normal to start, but started and idled fine, then cut out when revving up. This continued - whenever I rev'ed up for cutting it would initially start to rev then drop back down and either sound like it was going to cut out, or actually cut out - exactly as it does at the end of a tank.
So, I thought bad fuel? But the 2nd tank came from the same jerry can as the first tank, albeit the last "dregs". The jerry can is "clean" ie no visible contaminant. I pulled out the fuel filter and it looks pretty clean / good, no blockage. The air filter also looks fine, it's original, but pretty clean. I figure spark is fine as it starts OK and can idle for ages no problem and can even rev up for a very short time (a few seconds). A friend suggested I ensure the air entry to the fuel tank isn't blocked - he thought there would be a pin-hole intake with a flap - but the fuel tank cap doesn't appear to have anything like that, it appears fully sealed (which begs the question, how does air get into the fuel tank?) so I don't know where to go to clean the fuel tank air intake.
Another friend suggested it could be water in the water carbie and clean that - but I don't know how to do that (I'll check out youtube now and see if the manual tells me how) - would that give the symptoms I have do you think?
I think it could still be a fuel line blockage as that fits the symptoms in my limited experience and knowledge, but I don't know how to check and clear the fuel line.
Any thoughts or suggestions of what I should do? There are a couple of shops that could help, but one is run by total morons, and the other is so busy they can't look at it for a while and charge pretty hefty prices for service anyway (this would be a $200 job). Any advice gratefully appreciated.
Hope you are all enjoying a warm Christmas, whether you are a Southern Hemispherer like me getting it from Nature or a Northerner surrounded by snow but with a warm fire heating you through![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
