What is the tool called or what is everyone use when cleaning out the dirt from the groove on the chainsaw bar.
Zap
Zap
smokinjay said:I use a screw driver and air hose. and make the nose sprocket whisle.
zapny said:smokinjay said:I use a screw driver and air hose. and make the nose sprocket whisle.
Must be a small one.
Thanks
Zap
webie said:I use this combo tool from oregon .
http://www.baileysonline.com/itemdetail.asp?item=15225&catID=1661
LLigetfa said:My pack-sack has a small screwdriver in it that I use for carb adjustments and it is small enough to fit in the groove. I start at the nose and work back from there so I don't pull dirt into the sprocket.
Be careful with compressed air around the sprocket nose. You could drive dirt down into the roller bearings.
Mass. Wine Guy said:A thin putty knife works, too.
Cowboy Billy said:I ground the screwdriver end of my bar tool flat and put a hook on one side to clean it out. It still works to tighten the chain adjuster. That way I have all I need right with me and not have to carry a extra tool.
Billy
Cowboy Billy said:Sounds great Zap get one for me!
Its a little blurry but thats what mine looks like now. The bottom center is stock. Bottom right you can see how I ground it flat to fit into the groove.
Billy
