You sort of answered my question.  For the homeowner type here, who cuts maybe 2 cords a year, is there any advantage to a full chisel versus safety chain?  I mean how often/likely is a kickback and then with full PPE is that a significant worry.  I cut 2 flowering cherry trees this weekend and with a 32" trunk, my Stihl 251c labored pretty hard on a full depth cut (16" effective cutting bar length).  I always wondered if a full chisel would have saved me any appreciable time or effort as it took 15 min or so to cut the trunk around.
While semi-chisel chain will feel less "grabby" than full chisel chain, the shape of the tooth does not determine whether the chain is low-kickback or "safety" chain.
Stihl examples:
RM   = seim-chisel, pro (yellow)
RM3 = semi-chisel, low-kickback (green)
RS   = full chisel, pro (yellow)
RS3 = full chisel, low-kickback (green)
Essentially, the most common feature I see that makes a chain low-kickback is the guard link, but you'll also see bumper tie straps (tie straps with a protrusion as seen on guard links).  These features reduce the amount of wood each cutter link "bites" when the chain traverses the
kickback zone of the bar.  The kickback zone is the top quadrant of the bar tip.
The best reduction in kickback forces is achieved when using low-kickback chain with a low-kickback bar.  A low kickback bar has a smaller diameter at the bar tip.  This smaller diameter translates into a smaller kickback zone.
TO ANSWER YOUR QUESTION ON ADVANTAGES:
Low-kickback chains, regardless of tooth shape, don't plunge/bore cut very well.  I also find them more difficult to sharpen both when running a round file through and when using a flat file on the depth gauge.
TOOTH SHAPE:
As a separate issue, semi-chisel chain on average will cut a little slower than its full chisel analog.  On the other hand, semi-chisel chain often will keep its cutting efficacy longer between sharpening.  That's because once the sharp point of a full chisel chain is worn, it loses a lot of it's desired cutting characteristics.  For this reason, many sawyers find that semi-chisel chain seems to do better in "dirty" wood that tends to dull chains more quickly.
