C
charly
Guest
I wonder has anyone left some canola oil outside below freezing temps to see what it looks like ..wondering if once in your oiler lines and the saw sits over night if you have a waxy sludge to deal with...I can remember using canola oil years ago when it was cold out , but I think I followed it through with regular bar oil after warming it up... I can tell you years ago when I was out at Harley Davidson service school,,, the one instructor in our engine class said to get the nicest finish final honing a cylinder,,, use vegetable oil...He said the only down fall was in a shop environment it had to be meticulously cleaned up or it would start to stink after a while...When I did line clearance around the power lines,, just the hydraulic oil lubed the stick saw chain that ran the bucket truck...and in a pinch I used that when it was cold in my saw as well.. Myself I'd rather not pollute, I like the Amsoil synthetic bar oil,, not made from crude and man made,,, does it still pollute? Just read that it is semi synthetic,, probably the tack factor that is added... Part of the MSDS info: Section 13: Disposal Considerations
If this product as supplied becomes a waste, it does not meet the criteria of a hazardous waste as defined
under the Resource Conservation and Recovery Act (RCRA) 40 CFR 261.
