Okay, my new large CFM stove and new straight-up flue burned beautifully at first. I put a bad log (half-seasoned and maybe a little damp) on a few days ago. Frustrated that it wouldn't burn, wanting to go to sleep, and not wanting to run through the house with a smouldering log, I *very stupidly* (because I am a stupid noob) tried to put it out by smothering it with half the contents of my ash pail and closing the damper. I awoke the next morning surprised to see the darn thing still "burning" under all that ash as coal with no flame.
Yes I know this was incredibly dumb. I need to fix what it did, though. At first everything seemed okay, but yesterday I noticed the stove wasn't drawing well, and when I put several sticks of bone-dry super-cured dogwood on last night and couldn't even get *that* to burn well (in the past this wood goes up like a torch and burns down to fine, fine ash--and quickly, but last night it just kind of smoldered into coal) I decided I had plugged the cap (from reading this forum) & must go up on roof to unclog it.
I called the reputable local fireplace establishment who just installed my new flue and asked them what tools I would need to take with me onto the roof to get the cap off because I only wanted to have to go up there once, and their response was as follows:
1.) It's impossible that you have a clogged cap after so little time and one bad fire. New wood stoves are just difficult. Burn it with the door open and try to burn it (the creosote, if there is any) off.
2.) I don't know what tools you need to pop off the cap, I'd have to look up the Metalbestos information. I think maybe you can just knock it with a screwdriver and get the creosote to fall back down the pipe (
-why would I want to do this rather than remove it?
3.)(again...)New stoves are just hard to burn. I've been burning mine for three years and have never had the chimney cleaned out, because a new stove won't let you burn unseasoned wood, plus there's a secondary burn chamber, so it won't let you build up creosote. Because they're so hard to burn I usually have to leave the door open for my first fire.
So... I stupidly believed the guy, because I didn't want to face reality, and tried to light another fire. Close door, fire completely goes out. I felt around the air inlet to see if I could tell if it was clogged, but it seems to let air into the 2ndary combustion chamber instead of the main firebox (???-maybe I am wrong about this but that is what it looks like) so I can't figure out how to get access to it. Can anyone tell me how to check this? Also I suspect a trip to the roof is in order and I am not happy about it but if anyone can tell me what tool I need to get the cap off, and what I need to do with it after I get it off, I would sincerely apprediate it. Also, while I'm up there, should I run a burlap bag full of pine cones down the flue (after raising it from the stove and putting a plastic bag around it) to knock of creosote, or will the buildup likely be thin and not amenable to this kind of cleaning?
Yes, I am an idiot, if there is a flue-cleaning faq show me to it and I will read it. I didn't see a sticky.
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
