greythorn3 said:BeGreen said:greythorn3 said:ok guys i will do a 8x8" grid of screws then! u think i should start from the inside and work out wards? or start at a edge and work across?
I can't see why either would make a difference. Take your pick.
PS: I forgot to ask. Did you end up skinning the top of the studs with sheetmetal before you put down the cement board?
yes i skinned with some ducting sheetmetal i had the center area around the studd i put across the top because thats where i think the stove will go, gave my durock a wavy appearance tho. but im sure the thinset will fix that.
With the skin of metal the top of the hearth is like a drum. Add the cement board and it is going to be very solid. The waviness though may be a problem unless it is only a 1/16" or so. On the top layer, you want a completely flat surface for the tile and stove.
