Correct. 18" is the minimum clearance for single-wall pipe. No harm in exceeding the minimum. Yes, check that the pipe and support box are plumb.
Once begreen posted the folded over sides i thought i screwed up
! Good info thread though! ![[Hearth.com] Cathedral Ceiling Support Box [Hearth.com] Cathedral Ceiling Support Box](https://www.hearth.com/talk/data/attachments/116/116033-6564e74deb3ce9a31fd7beb0480dc19e.jpg?hash=k29WSXu2Q5)
Thanks
That is where the the tar is to go. not around the storm collar. I wouldn't get up there now, but in the daylight pick it off and replace it with silicone.I did roof tar around the circle part of the flashing and the vertical line that goes up the circle part of the flashing.
Slip sections for single wall are 18". In Double wall they make telescoping kits as well as a short slip that goes in a standard piece of pipe, they are typically like 2-10" of adjustment.Do they make a slip section the size of a two foot section?
? I would use a putty knife and slowly "cut" it off. You could use a colored silicone so it will cover any left over tar. Just for looks.How easy is it to remove how do I do it?
